a week ago
Recently I have been unable to send or receive photos though text is OK. I have updated my APN settings,
re-booted the phone and tried everything else I could think of. Is there a solution?
My phone is Asus Zenfone ZB555KL with Andriod 8, about 4 years old.
Thanks
a week ago
(or try all upper case SP.MB.COM)
This did the trick. Thanks everyone.
a week ago
@dm250, sounds like you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
a week ago
You can try a network reset of your phone (this will erase your saved wifi passwords)
Maybe screenshot or copy and paste your APN settings.
One small typo may cause issues.
a week ago
does your phone has a newer OS you can update to? Check and update it
And there might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
a week ago
Thanks Dunkman, I saw that announcement and updated my settings but still no go.
a week ago
There was a recent announcement about MMS messaging:
You could try setting your APN settings to following:
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
