10-11-2024 09:52 PM
Hi. For the last 3 days my mobile internet has been working in a really strange way. Messaging apps like Telegram and Whatsapp takes a long time to receive or send messages(especially media like photos and audios). Also some websites can't load at all, but others work normally. I have been trying to narrow down the problem until I realized that turning my VPN on would totally fix the problem! I tried to reset network setting, reboot phone, turn air plane mode on and off, and checked the APN settings and nothing worked. WIFI works normally though. My wife is having the same problem on her Google Pixel 7 and I have a Samsung S22. Is there a problem with Public Mobile's network or is it something on our end?
Thank you.
4 weeks ago
Nous apprécions votre signalement. Un agent assiste déjà le client et veillera à ce qu’il reçoive le soutien nécessaire
4 weeks ago
the TELUS DNS servers ignore TTY udpates and do not fresh properly.
10-13-2024 10:18 PM
I feel that too. Even after a few days, it's kinda like that, I hope there isn't any issue with the porting in from other carriers to Public.
The data is kinda slow, and even streaming music is facing lags, in certain places in Vancouver. Calling seems to be okay 👍🏻
10-12-2024 04:45 PM
You are not dreaming, this has been happening all over the lower mainland the last few days. I have verified it with multiple accounts. There is something wrong with the throttling/data routing system at Public Mobile/Telus.
10-12-2024 02:15 PM
Oh I see. I see that the speed is good then. I was in my room, when I did the speed test in the morning.
If I go outside, it might have been more. I am towards East Van and it seems okay.
Lemme go out & check.
Just checked, its around 90-110 Mbps outside my place!
10-12-2024 02:11 PM - edited 10-12-2024 02:12 PM
I got a reply for my support ticket and they said that all looked well on their side, but they refreshed my account and for me to wait 10 mins before restarting my phone and then monitor the data issue for the next 24 hours.
10-12-2024 02:08 PM
hi @Ohtani17 the issue for Vancouver should have been resolved last night around 7pm
but try to change the network mode to 3G only or WCDMA only and it should help
and test on another device
10-12-2024 02:06 PM
Yeah, I'm in Vancouver.
10-12-2024 02:00 PM
I see. Where are you located? Lower Mainland or somewhere else?
Mine is also the $34 - 50 gigs, but I preferably use it as LTE+
I guess its depending on location to location
10-12-2024 01:58 PM
Yeah, I hope it's something they can fix soon. At least your speeds are a lot better than mine! I only get around 10 Mbps, lol and a lot of times things won't load because the connection keeps dropping or it plain isn't working.
10-12-2024 01:55 PM
Maybe, we will wait & see! Its okay
10-12-2024 01:54 PM
Hi @Shubh2023 if VPN works, then might mean it is a DNS server issue. Possibly
10-12-2024 01:43 PM
Maybe you are right, @Ohtani17
I guess its something which is impacting a lot of people! Is it just happening in BC or somewhere else too? I just did a speedtest, with LTE+ & the speed is around 60-80 Mbps
10-12-2024 01:41 PM
Well, I see. Yeah, its kinda slow. I have not used the mobile data since today morning, so I have no clue.
Lets see how it goes for today. Maybe there is something going on, thats why its happening for a couple of days!
10-12-2024 01:27 PM
Thanks, I will do that. I came to the forums to see if anyone else was having data issues and I did find more than one post complaining about it around the exact same time it started happening for me too.
10-12-2024 01:24 PM
hi @Ohtani17 usually testing in another phone is a good enough test and don't need to Reset Network
I think you should ask support agent to. refresh the account on the system
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
10-12-2024 01:22 PM - edited 10-12-2024 01:23 PM
I'm on the 5G 50 gigs plan. It's a Pixel 6 and I tried the sim in another phone with the same results. I didn't try to reset all networks cause I didn't want to lose all my wifi networks and bluetooth connections.
10-12-2024 01:21 PM
hi @Ohtani17 what plan do you have? a 5G plan?
and what phone is that?
did you try Reset all networks or try the sim on another device?
10-12-2024 01:19 PM - edited 10-12-2024 01:21 PM
I've also been having the same data problem since around the same time and it's still broken for me. I'm on the 5G 50 gigs plan. Data goes real slow or drops connection. When I run a speedtest sometimes the connection doesn't last long enough for it to finish.
10-12-2024 02:49 AM
Well, it was not working so well since the morning of Oct 11th in Vancouver. I was outside till 6pm in the evening, and the internet was coming and going. Texting was working fine, just the apps using data was facing hinderance.
I hope they (PM) look into it soon!
10-12-2024 12:12 AM - edited 10-12-2024 01:06 AM
I did not have to try the 3g because it came back to work now. But if it happens again I will do that. Thank you!
10-11-2024 11:36 PM
HI @Sout
did 3G or WCDMA only help? and some people said 4G and 5G start working again. Please reboot phone and try again
for Telus status update, best to check here:
https://telus.com/en/bc/outages
it usually has accurate update with BC and AB, not very well with Ontario or the Eastern provinces
But come here , the PM Community, you will see announcement by PM as well as issues reported by the fellows customers
10-11-2024 11:36 PM
It was working good this morning but in the afternoon it started to show problems again. I just don't understand why using a VPN fixed it for me. I will try setting to 3G to see if it helps. Thanks!
10-11-2024 11:33 PM
Yes I'm in Vancouver. Is there a place in the website or app that i can check the status the service? Or maybe a blog from public mobile that they post about stuff like maintenance or service updates?
10-11-2024 11:24 PM
HI @JazzyB
changing to 3G only (or WCDMA Only) should help a bit, data should work just at a slower speed. The speed would be around 15Mbps, better than nothing
but many confirmed that 4G or 5G has came back. Please try to reboot your phone and Reset All networks
10-11-2024 11:23 PM
I am having the same issue. Changing to 3G wasn’t very helpful. When will this be fixed? It’s been going on for 2-3 days now.
10-11-2024 10:19 PM
HI @Sout
are you in Vancouver, BC? there is current some data issue there.
A quick workaround is to set the network mode to 3G only or WCDMA only.
