02-14-2025
05:49 PM
02-14-2025
07:31 PM
computergeek541
02-14-2025 09:29 PM - edited 02-14-2025 09:30 PM
You need to remove that other sim card and leave only the PM sim there. then try Reset Network Settings and let it program the speed dial key 1
Add: let's continue trying whole wait for PM to reply. I still think this is fixable by you
02-14-2025 09:28 PM
You need to contact a CS Agent to ask them to reset your SIM and Network on their end. This will push notification to your phone which will set the voicemail number. I'm telling you, THIS is the way to do it. I've already shared contact links in this thread.
02-14-2025 09:05 PM
Yes
02-14-2025 09:02 PM
Do you still have another sim card or esim? Another one from your old carrier
02-14-2025 08:41 PM
02-14-2025 08:40 PM
Samsung s20 fe unlocked
02-14-2025 08:36 PM
Good, use that for now.
Btw, what phone you have? Let me check why your device locked the manual update, it shouldn't
02-14-2025 08:28 PM
Ok so I can quick dial fron number 2 using the number. But still unable to with number 1 as it is still having issue
02-14-2025 08:10 PM
i posted the number to you already
Let's do it again. First, try calling this number and see if you can access your VM:
1-705-780-4001
or try this
1-647-580-4001
02-14-2025 07:57 PM
As stated I cannot use a quick dial. I don't have a number for VM
02-14-2025 06:58 PM
Try to see if PM can push the number to you
For now, set a speed dial on another digit to call VM
To have PM to help, open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
02-14-2025 06:57 PM
I cannot access my voicemail via the long press 1. I don't have a voicemail number and try to input a few numbers and it says I can't change the number what can I do. I've reset network and removed sim twice. Message has been sent to CS
02-14-2025 06:49 PM
Please use the chatbot to open a ticket: https://widget.telus.tiia.ai/publicmobile/publicmobile.html?lang=en
If you receive an error message that you are unable to open a ticket, send a private message to a CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 .
02-14-2025 06:47 PM
It says voicemail number can't be changed
02-14-2025 06:45 PM
Didn't work. Not sure if I went to right place
02-14-2025 06:43 PM
On your dialer settings, voicemail settings screen, set this number there
1-705-780-4001
And test again
02-14-2025 06:40 PM
Not working it's same as previous message
02-14-2025 06:27 PM
Just click Reboot network settings and it will push the number down to your phone
02-14-2025 06:00 PM - edited 02-14-2025 06:01 PM
Hey @NathanPardy
This should be a pretty simple fix. If you go into your network settings and refresh them, then reboot, this should reset them and the phone will recognize PM's number to call voicemail
You can always manually enter the phone number for your voicemail. Here's the list.
