07-28-2025
08:21 AM
07-29-2025
01:20 AM
computergeek541
I keep getting voicemail notifications when I check my voicemail I have no messages, android phone. Is there anyway to stop this?
07-28-2025 08:52 PM
@Trentmac wrote:I keep getting voicemail notifications when I check my voicemail I have no messages, android phone. Is there anyway to stop this?
Call your number from another phone and leave a message. Use your cell phone to listen to the message that you left yourself and delete it. That will resend the request to clear the icon. Some phones have a clear voicemail icon choice in the menus.
07-28-2025 11:15 AM
Ok I cleared both cache.
I did come in from Bell but had my voicemail shutoff and never had this happen before PM.
Hope for the best
07-28-2025 10:41 AM
Settings > Apps > Show System Apps > Phone Services > Clear Data
(please note the Phone Services and different from the Phone App, so try Phone services as well)
and did you just change from another provider? that could be an issue if you are moving from a carrier that has Visual Voicemail feature and PM does not
07-28-2025 10:20 AM
Cleared the cache and still getting reminders every 2 hours of a new voicemail which there is none. On my Samsung s22
07-28-2025 09:08 AM
Ill try that and see if I get the same notification tomorrow
07-28-2025 08:46 AM
07-28-2025 08:40 AM
I have an s22 samsung android thanks
07-28-2025 08:33 AM
@Trentmac do you have iPhone? If so, the notifications are from the Live Message feature of iPhone. Disable Live Message and you won't have that
