10-11-2026 11:37 AM
Hello,
I have a 50 GB US Canada plan, but it does not seem to be working in the United States today. I have made sure data Roaming is turned on, voice and SMS is working, I have Power cycled the phone. It is an iPhone.
any advice?
10-11-2026 02:46 PM
@Chris_s1 it is not a network issue but a device problem
10-11-2026 02:44 PM
interestingly, I had 3 PM phones in my group, one automatically connected to Verizon and worked, two connected to att and had to be forced to Verizon before they would work
10-11-2026 12:26 PM
So I needed to switch my network to Verizon instead of automatic.
att did not work for me
thanks!
10-11-2026 11:58 AM
try turning Airplane mode ON for a few mins...then turn it OFF. See if that helps.
10-11-2026 11:41 AM
I should add that my child who also has a us roaming PM plan is able to use cellular data
10-11-2026 11:41 AM
Critical part to US roaming depends on T-Mobile/AT&T/Verizon coverage and whether you can connect successfully onto either network.
If data does not work, change the Network Connection from Automatic to Manual and select and test each of the three and see which one you can connect and work best
Also, check if you have disabled your mobile data limiter. Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
