12-30-2022 08:08 PM
12-30-2022 09:00 PM - edited 12-30-2022 10:04 PM
12-30-2022 08:40 PM
From your description, sounds like your going to have to ask for that code from a Customer Support Agent, by using the Chat Bot Simon to get a service ticket started first.
The link is at the bottom of this page.
12-30-2022 08:20 PM
@smythdon55 If it is the SIM PIN you need, then the default PM SIM PIN is 1234 unless a new PIN was created for the SIM.
A phone PUK code would need you to contact the previous provider if the phone was purchased through them or if it's Samsung, then phone their customer support and they will provide the unlock code too.
12-30-2022 08:10 PM - edited 12-30-2022 08:10 PM
What was the exact error? You sure it is SIM card PUK it was asking for?
If it is sim card PUK and the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing "Locked SIM"
open a ticket with PM Support using this direct link: https://urlshortner.tiia.ai/Oyn1L6
