Good luck with double payment
rusty69
No admin help at public that's for sure
As stated previous post.
Overcharge will remain as credit in the account…so funds hasn’t disappeared unless members are hard up for funds and wanting a refund.
@rusty69  Seems like you tried to use Chatbot earlier and didn't have any success
Yes, Chatbot usually just provide information.  For actual support from PM, please open ticket with Chatbot.  You can follow Method 1 below to open ticket with Chatbot.  In case it is too confusing, open ticket with them via direct message (Method 2):
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
HI @rusty69   No.  there is always help with issue like this
I had issue with PM payment and they helped me sort it out within a day
You just need to open ticket and check message and reply them.
You opened ticket yet?  If not here you are:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
HI @rusty69   so, did you login to My Account and confirm the account status?
was that PM took the money and your service still disconnected?
or PM autopay failed and you have no service?
@BKNS27   , @rusty69 was not the OP in the other post in August.  OP just joined today and happened to reply there today
@rusty69   Pre-Authorized payment could fail, it could be a your credit card issue or more chance a problem on PM
but no worry, just login to My Account and make a manual payment.  Click on the button "Reactivate my plan" and follow the steps to complete the manual payment
You can also use *611 to make the payment by amount due, but this requires you to know yoru 4 digits pin
