12-27-2022 09:20 PM
I am new to public mobile and looking for some information.
When I sign in, it says my account is active. But, for some strange reason I
can not call out or receive calls and it says on my phone that I don't have a sim
card. Do I have to activate my SIM card separately on the website or should
it already be done? Any assistance in this matter would be appreciated.
12-30-2022 09:11 PM
Hi softech
I just wanted to thank you very much for your assistance with my issue with cell phone. It is working now.
12-30-2022 09:11 PM
Hi Halimacs
12-27-2022 10:58 PM
12-27-2022 09:28 PM
@be77yboop so, you are able to login to My Account? If so, you have completed the activation
HOWEVER, since you cannot make calls out and not receive calls, it looks like the system has not properly provisioned your Sim card.
No worry, it is an easy fix, you just need to open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
Also, try to reseat your sim card once more while you wait for support to reply. Power down the phone , take the sim card out from the tray , then put it back FIRMLY, and power up the phone
12-27-2022 09:21 PM - edited 12-27-2022 09:23 PM
Yes, you do @be77yboop
You need a credit card and an email address, and the SIM card in hand. Then click activate on the top of the page.
If you've already done this, did you reply "yes" to the port authorization text from your prior provider, leaving your old provider SIM card in while doing this? ( if you're porting your number here from elsewhere).
Then try rebooting your phone and you should be good to go.
