Activation
11-25-2024
05:09 PM
11-25-2024
05:10 PM
computergeek541
I tried to activate my sim a lot of time but it always saya subscription not activated.
Joining Public
11-25-2024 05:12 PM
In app is easy and fast. Follow the promise and you should be good to go.
11-25-2024 05:11 PM
@Pekpek And your using a brand new PM sim card and using the app to activate not website ? You need new never used sim and app to activate if same support can help
11-25-2024 05:11 PM
hi @Pekpek
is that eSIM? if it is for eSIM, check if the eSIM already installed. Check your Sim Manger and see if a Public Mobile eSIM there
if not, ask support agent for help
you can submit by direct message:
11-25-2024 05:11 PM
@Pekpek have you installed the Public Mobile app on your phone and completed the activation through the app? It seems that some customers are forgetting this step and think that they can do it on the website which you cannot.
