Roaming in US and texting photos
Grets
I bought the US talk, text, data plan and just arrived.
While I can text SMS, I can't receive photos and my roaming doesn't work ... Any ideas?
23 REPLIES 23
Texting out?
Yes you might think that but have you actually checked the account? maybe the phone did a whole data dump to a cloud account or something.
It would be useful to verify the calling function. Call your husband, see if it works. Remember the 1 in front.
So the phone does have 5G. And you did set it to 4G LTE?
It said you have to download? or your husband said you have to download. The word "attachment" might also mean something else. Are you sure he's sending you a pic through texting? Or email?
Grets
Haha no one to phone yet, but yes SMS texts.
There's better be data left! I only got here last night.
My phone use 5G at home.
My husband sent me an attachment said I have to download it, but that never happens..... Just uses up battery power
dust2dust
Can you otherwise make calls and send real sms texts (not using RCS)?
Is there any data left in that 3gb? I guess it says 13/15 days but what about the data quantity?
Does the phone even have a 5G setting?
When someone sends you an MMS do you get the pre-notification? Then it doesn't download when you tap it?
Grets
Thanks! yes, I bought it on the 6th...
@Grets
looks like a CSA intervention is req'd. Here's a link to send them a message.
Log in to your account (on a laptop preferably) just to make certain that you successfully loaded the correct add-on. By all accounts it should be working properly for you by now. Did you have this add-on before today ?
Grets
Pixel 6a
Grets
Yep
HI @Grets
did you try Reset all networks?
@Grets
it might help if you tell us what make of cellphone you're using ?
Grets
Nope. Still no roaming connectivity. Guess I'm stuck without it.
HI @Grets
try connect to AT&T again but change network mode from Automatic (or 5G) to LTE.  You seems to be connecting to AT&T but with AT&T , they only able to provide LTE service for PM roaming customers
@Grets
make sure Roaming Data is enabled in phone settings.
Grets
Did that. No change. T Mobile shows LTE+ and that ! in the connection triangle.
Att shows 5G with the connectivity flickering off and on
@Grets
try Reset all networks/Reset Network Settings once, then try manually connect to T-Mobile and AT&T
Grets
Outside of Boston mass ... Tried all of the above
@Grets
which states and city you are at?
try to also manually connect to AT&T
@Grets  Maybe try resetting the network settings and see if that helps at all
Grets
T Mobile auto selected. I bought the $30 US plan for 15 days
Grets
I had not rebooted, sm attached to T Mobile and when I turn roaming on, I get a ! Next to the triangle thing
DDM69
@Grets  Do you have data roaming turn on in your phone settings ? And are you connected to T mobile or AT&T and reboot  the phone
dust2dust
Turn on roaming data. Turn on cell data. Set networks to 4G LTE.
What about calls?
DDM69
First of all, which plan did you purchase?  Any more details would be very helpful.
Have you tried to choose T Mobile?
