Refer a friend
Jess19
I gave my code to my sister and she used it months ago and I still have never received the reward for it. She got the $10 off and I haven’t gotten anything!
Yummy
If she got $10 that means referral worked.
Log in and check what it says regarding rewards. You should see last 4 digits of her phone number.
VIP_Tech
CountyDownIeUk
@Jess19
Logon to your My Rewards, look at the referrals and see if her last 4 digits are there.
@Jess19
Did you login to My Rewards site (https://www.publicmobile.ca/myrewards) and check the Refer-a-friend section and check to see if your sister phone number there?
If you checked and it's not there, have your sister to open a ticket with PM and explain to them that only she got it but not you (the referee)
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
