Incoming calls
Z32
When my phone number gets called it connects to someone else, but out going calls are fine
@Yummy wrote:
@softech wrote:
If you activate by picking new number, likely the portal has given you the wrong number.   The number is already owned by someone else.     This is a glitch that PM system has sometimes
So how is that possible? What would you do if Your number appears in number-pool and somebody pick it up?
Should't picked numbers be out of circulation?
@Yummy    It was a common glitch.  In fact , it is a common glitch for Telus family (not just PM, but PM/Koodo/Telus all  use the same number picking system)
It happens more often like 6 months ago.
No worry if someone picked your number, the newbie has to go and pick another number instead.
@Z32   did you just activated and picked a new number?
Since it is someone else number, you have no choice but to pick another one.
Please login to My Account and select Change Number
https://selfserve.publicmobile.ca/Overview/ChangeNumber/https://selfserve.publicmobile.ca/Overview/ChangeNumber/
VIP_Tech
Hi @Z32
are you activate new line with new number or you did transfer your old number to PM.
