yesterday
- last edited
4 hours ago
computergeek541
I was on the $15 plan for a while. I changed to $34 plan as I wanted US data while visiting my daughter in the states. Now I want to switch back to $15 plan but it is gone from the options. The cheapest plan available is now $29. Any way I can go back to $15 plan again? I don’t use my phone very much so I don’t need a lot of data
3 hours ago
thanks for the update...I wasn't aware that PM does this now.
3 hours ago
Plans are now tailored to each customer. What may be available to your account is not necessarily available to everyone. I run many accounts and see different offerings.
3 hours ago
At the moment your choice are to get the 29$ plan or if your number not important to you. You can close the account and start another and get the 15$ plan for new customers. If your number is important to you .you can port it to another provider that has a 15$ plan like fizz
3 hours ago
@hairbag1 wrote:you old $15 plan has been removed from the menu...but...this one might be a good 2nd choice. It even has a bit of data for your use...
The customer has already incidcated that the lowest priced available plan is $29, so unfortunately, the $19 plan isn't available.. Different plans are available to different Public Mobile customers.
3 hours ago - last edited 3 hours ago
edited
4 hours ago
@Hye wrote:I was on the $15 plan for a while. I changed to $34 plan as I wanted US data while visiting my daughter in the states. Now I want to switch back to $15 plan but it is gone from the options. The cheapest plan available is now $29. Any way I can go back to $15 plan again? I don’t use my phone very much so I don’t need a lot of data
Sorry, but the $15 plan isn't available to existing customers. Since it's not listed in your account, the plan is unfortunately no longer available to you.
