03-08-2023 12:52 PM
I paid my bill today on auto pay. I changed to a better plan and was charged $42.00 when I should have been charged only $2.00 on the GST???? How do I get my refund?
03-08-2023 01:10 PM
HI@Peter57 what plan did you change to ? did you change to $40 plan and got charged $2 tax?
and did you make a plan change using Chnage plan now? And did you change plan right after renewal?
if you just renewed, you then make a plan change using Change plan now, PM will charge you full price even it just renewed you couple hours ago. If this is what really happened, submit ticket to CS agent and maybe they can help
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-08-2023 01:09 PM
Are you in Alberta? NWT or Nunavut? It appears you expect to only pay 5% in taxes. And you are now on a $40 plan? But if you have a phone number from another province...you pay the taxes based on the province of where the number belongs too. Any ways check your transactions and your CC statement. Transactions show and do NOT include taxes and your CC does show with taxes.
03-08-2023 12:54 PM - edited 03-08-2023 12:54 PM
Take a look at MY ACCOUNT, Transactions.
If you are due a refund....leave it in your balance and it will be used first for your next cycle.
03-08-2023 12:54 PM
You are supposed to be charged whatever your new plan cost (minus rewards) if you did schedule plan change on next renewal.
If you did change plan now you will be charged full amount (no 'minus rewards').
Why do you expect to be charged only $2?
