Old number doesn’t work after porting
Keii
Hello I transferred my old phone number to public mobile while it was still active, I also received the sms for transfer approval and I replied yes to it, it has been a 2 weeks and the number is still not working. I am unable to send or receive messages through the old number. What can I do?
thank you in advance
11 REPLIES 11
Keii
I’ve removed the sim card now, I have the primary number(public mobile) and secondary number(old number).How do I make my old number now as the public mobile number?
Yes, remove your old SIM card and make sure under your sim card manager you associate your service with the esim.
What's likely happening is your device is trying to read the service off the inactive prior mobile service provider SIM card.
HI @Keii
it is a esim setup problem and not port
check your Sim manager or Cellular screen on Settings, do you see a PM esim there? if it is there, make sure i tis enabled or "turn on the line" is on and set as Primary
if the esim is not there, check PM Welcome email and scan the QR code to install
@Keii  Yes take old sim out and check phone setting for sim manager and ensure PM is set to primary
@Keii Send private message to CS_Agent to sort this out.
Keii
I got esim, I still have my old sim card inserted. Do I remove it?
 I’ve tried rebooting and network reset buy still doesn’t work
@Keii  Please submit ticket with CS agents to get fixed
send  a  private message   To CS_Agents
Keii
No, it doesn’t work anymore, on the day we did the porting, it stopped working. I got esim, everything is not working, even calls and data
HALIMACS
@Keii
This may go without saying, but after you replied yes to the port authorization text while you're old SIM card was in your device, did you then replace it with the Public Mobile SIM card?
After that do try rebooting the device and resetting network connections and toggling airplane mode on and off to see if you could get the connection established.
Phil_Adelphus
@Keii   Does your old number still work on the previous provider's sim?  Did you get a public mobile physical sim or esim?    Is it just text messages not working, do voice calls (incoming and outgoing) and data work?
@Keii  No worries I’ll send you the lodging team number private message and they can re trigger the port request for you
