Monday
On Step 6 of 6: Activate. "Subsciption Not Activated".
Cannot proceed any further, I've tried using the 'Get Support' with the ChatBot, it asks for a log in, I do and just get a white screen, nothing else works.
Can I change my activation to using a physical SIM rather than an eSIM and porting my number to that SIM?
Monday
@pfTony You can use this direct link to support
private message to support .
send a private message To CS_Agents
Monday
HI @pfTony
no need to change the sim card. It is an activation problem and not really an esim problem. Check with support agent, they might send you a new esim to install
please submit ticket by direct message:
