01-07-2024 02:43 PM
I am a new customer. The eSIM was unable to activate on my phone so I have no service. My phone # that I transferred from the old provider is now with Public mobility, which I no longer have access to and is the # the security code is sent to. I tried all the means to contact PM with no avail. Any suggestions?
01-07-2024 03:24 PM - edited 01-07-2024 03:28 PM
@Ra10 Happy my suggestion worked for you
Welcome to public mobile and happy new year
https://productioncommunity.publicmobile.ca/t5/The-Lounge/Re-Ra10-not-getting-service/td-p/1125389
01-07-2024 02:46 PM - edited 01-07-2024 02:47 PM
@Ra10 Check your phone setting sim manager ensure PM is set to primary and “turn this line on” is toggled on (iPhone) and reboot the phone
if still no luck you can submit ticket with support . Using this direct link
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
01-07-2024 02:44 PM - edited 01-07-2024 02:44 PM
Hey @Ra10
You can reach a CS Agent with this link.
