No phone activation
Jozefsolik
How to activate my phone
10 REPLIES 10
@Jozefsolik    Were you porting over your number from another carrier?  Did you keep the SIM from the old carrier in your phone to respond with a YES to the porting authorization text within 90 minutes window?   The old account also needs to stay active until the porting is complete.
If you missed the transfer text request, I'll private message you the Telus Porting Dept. # to call and they can ask your previous carrier to resubmit the transfer text, so keep their SIM in your phone until you've responded to it.  Please check your message box top right for the Telus porting #.
Jozefsolik
Is somebody still helping me?  No result with my activation problem
Jozefsolik
They took my money I can sign in my account but still no phone # transferred
HI @Jozefsolik chexk your credit card to see if PM took money from you.  And if you activated,  you would have a login setup.  Can you login to PM My Account?
And us the PM sim card in a phone now? can you make calls??
Alexandf
@Jozefsolik
open ticket with PM support and ask them to check it out.
 At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
Jozefsolik
When I try to activate the sim card I didn't have that code and now it tells me that I am with company but no activation on my phone
HI @Jozefsolik   are you trying to activate new PM account? or activate a phone?
if you are activating PM , do you have a new sim card yet?  Start with getting one from Telus or Koodo store
Once you got it , then you can activate by going to https://activate.publicmobile.ca
Also get a friend to give you a Friend referral code to save $10.  And possible another $25 for special friend bonus (not sure if it is a targeted offered or this bonus for all new activations)
JL9
You can get to the pic above by clicking on the activate tab at the top of your screen. Do you have your sim card already? Do you know what plan you want to go with. Are you porting over a number?
DDM69
If you’re going to be a Public Mobile customer I’d recommend you get to know the website asap.
Good luck and welcome! 😊
Yummy
Have brand new SIM?
SIM already activated?
If you have PM SIM and activated account/service go to Sign In, My account and create self-serving account.
