12-02-2024 01:00 PM
Hi, I need to reset my pin so I can pay my bill to reactivate my account. I don't have any service right now.
Thanks!
12-02-2024 01:06 PM
Thanks so much!
12-02-2024 01:05 PM
is this a problem with logging in app or My Account? if you can login , you don't need to use the PIN to pay the bill
if you cannot login, and if it autopay already failed, you might not be able to use the PIN to make payment. Maybe you can get a voucher to reactivate account, you can buy it from drug stores or gas station or some voucher online site too
12-02-2024 01:01 PM - edited 12-02-2024 01:01 PM
hi @Jfish
use this link to reset pin
https://myaccount.publicmobile.ca/en/account/reset/pin
or you can buy voucher from Shoppers drug mart and load the voucher using *611
12-02-2024 01:00 PM
