11-29-2022 06:59 PM
I am leaving Public Mobile and there was an issue with porting out to Koodo. They require my account number again, and now when I try to sign into my PM self serve, my login (which I am confident is correct, used it yesterday to get my account number the first time) is coming us as incorrect. When I try to reset my password, I never get a verification code to my email. I can't request one to be sent through text, as my number didn't port properly and my PM account isn't active, and yet Koodo hasn't been able to port over the number, so it's in limbo.
Can I get some support from PM, to tell me my account number, so Koodo can attempt the port again?$
11-29-2022 09:00 PM
Is your koodo account prepaid?
This may explain the problem with the phone number transfer and the need for the account number after the pm account has closed but the phone number is not on the koodo account. The prepaid "issue" goes both ways....the phone number has to be transferred between accounts back end....it's not actually being ported out.
11-29-2022 08:32 PM
11-29-2022 07:48 PM
Did you just update your solution @Ddenton28 ?
Just wondering - thought I had seen that you already chose one. Perhaps I was mistaken.
Glad situation resolved. 🙂
11-29-2022 07:09 PM
@Ddenton28 Just in case you need it, I'll send to your community mailbox a phone number to call too, to ask about your port request. You might need that too.
11-29-2022 07:07 PM
hi @Ddenton28 is your PM services still working? I think the port might have completed and therefore you cannot login
11-29-2022 07:07 PM
Make contact with Public Mobile Customer Support, @Ddenton28
11-29-2022 07:06 PM
@Ddenton28 Ok then, contact a CSA agent as I described above.
11-29-2022 07:04 PM
It didn't. Koodo does not have my new number, and when someone else calls my number that I'm trying to port out, it now says "The number you have called is no longer in service". I didn't otherwise notify PM, and my account was active/in good standing at the time of the port request.
11-29-2022 07:03 PM - edited 11-29-2022 07:05 PM
Your PM account number is in your self-serve, under your Profile tab on the left.
You'll then see it on the right near the bottom of that page.
EDIT: oops, sounds like you cannot access your self-serve - that means the port likely is in progress.
11-29-2022 07:01 PM - edited 11-29-2022 07:03 PM
@Ddenton28 Your port request probably worked if you can't log on to your account anymore.
To contact a CSA agent from PM, either send a private message to CS_Agent
or use the Chatbot Simon to get a service ticket for help. They help get your account number.
