12-03-2024 10:18 AM
I was in kodoo service before and I chose public mobile service I cancel my kodoo service now and keep my kodoo number I transfer my same number to public service but not the public service don’t work I already cancel my old service
12-03-2024 10:24 AM
hi @Bishnu
Try reboot the phone and try Reset all networks
if it is physical sim, try the sim on another phone. If esim, make sure it is set as Primary and set as Active (or Turn on this line is set)
if nothing works, ask support to check the account. you can submit ticket by direct message:
12-03-2024 10:23 AM
your old Kodoo account has to still be active in order to port in to PM.
12-03-2024 10:23 AM
Sorry to hear about your troubles.
More details would be helpful for the community members to offer better advice.
Did you activate eSIM or physical SIM card? Was your Koodo service prepaid or postpaid? Did you respond "yes" to Koodo port request text? How did you "cancel" your Koodo service.
Do you have any service with Public mobile eSIM or SIM card?
12-03-2024 10:22 AM
@Bishnu You shouldn’t have canceled the Koodo service before joining PM you need both accounts active to transfer number and once you have successfully ported number to PM it would automatically close your Koodo account . So you gonna have to check with support to give you new number or if they can get your Koodo number for you . But most likely you have to call Koodo back to activate that old number to port it over to PM
