12-03-2024 09:08 PM
12-03-2024 09:21 PM
The wait for customer service agent response is longer than usual. Depending on issue, can take 1-2 days for response.
Is there a specific issue that community members can help out with? Often, many issues do not need CSA help.
12-03-2024 09:20 PM
@AshMc
PM is an online service so all communication is done through private messaging.
But it might be quicker for members here to help with common issues.
So what is your problem?
12-03-2024 09:19 PM
@AshMc No one to talk to all support is online
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
12-03-2024 09:10 PM - edited 12-03-2024 09:10 PM
hi @AshMc
PM support is all online. So you can either post your question here and community members, customers, can try to help
or if you like proper support agent to help, then submit ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
