12-03-2024
10:15 PM
12-08-2024
03:15 PM
Dunkman
Hey, had public mobile a few years before and joined back again. How does the point system work for the community? Is it like if I answer questions, do I get points that will help decrease my monthly bill? I used to get like extra perks at the end of the year, like extra gigs. Though I don't need it due to my plan being great, just wanted to know how the pm has changed over the years. Also what towers do pm use in the US?
Rewards
12-03-2024 11:02 PM
hi @Munchking if you use the app, you can access Rewards by going to the Rewards tab
if you use borrower, login to My Account first, then there is a Rewards link on top right of the page
12-03-2024 10:47 PM
OH I SEE!, Thanks for explaining it. I think the rank thingi is pretty fun lol. I jumped from New in Town to Good Citizen in a few days. The rewards account is different than the normal account?
12-03-2024 10:39 PM
hi @Munchking the rank or tier like Mayor really means nothing, just for fun.
answering 1 or 2 questions a day will likely get you 5 points for the month, but again it depends on the overall participation. And remember, try not to give redundant answers as those don't count
1 point is $1. But the point will be collected in your Rewards account. You can redeem 15 points for $15 bill credit whenever you have collected enough points
12-03-2024 10:32 PM
Thanks, So basically, I don't actually get points per question I answer. It depends on how active I am? So Lets say I answer 1-2 questions per day will I be able to get around 5 points per month? And will it show in my bill? Finally , whats the teir method. Is Mayor the Top?
12-03-2024 10:26 PM
hi @Munchking not one question one point. PM awards different level of points based on overall participation.
Usually easy to get 1 or 2 points per month, like around 5 mins of participation (answer questions) a week will do. 2 or 5 points might need 30 mins a week, but 10 or 15 points would be a lot more effort
And the easiest point to earn is in fact friend referrals. Each friend you bring in will earn you 1 point per month. More friends=more points with limit at 110 points per month
12-03-2024 10:19 PM
@Munchking They use AT&T T mobile and Verizon in the U.S. and you now get 5% back on plan spend and all purchases like add ins , once a year you get 10 points back on your anniversary and frend refferals gives you 1 point for each friend every 39 days they say with PM once you have 15 points you can redeem $15 off your bill from the rewards portal . You can also use points to buy add ons at discount and use them the points to enter draws when they have them . check the rewards portal catalog and browse the different options
Points rewards portal view catalog
