12-03-2024 09:25 AM
Hi!
I just checked and I got some points from Public Mobile, however, I'm unsure how to redeem it.
I thought it will be automatically applied like the old way they do it, but seems like I need to do it manually.
How do you normally redeem your points?
Thank you!
12-03-2024 09:56 AM - edited 12-03-2024 09:56 AM
@Thaotran1 no worries you should also get email confirmation that you have successfully redeemed $15 off your bill and if you log back into your account you will see the $15 sitting in your available funds and it will automatically be used towards your next renewal , enjoy the savings 🙂
12-03-2024 09:50 AM
thank you
12-03-2024 09:48 AM
I figured it out on the app, thank you so much
12-03-2024 09:38 AM
@Thaotran1 In your account , rewards portal and browse the catalog to buy add ons or once you have 15 points you can redeem $15 off your phone bill
Points rewards portal view catalog
12-03-2024 09:36 AM
When you make a payment or purchase add-ons the option will pop up to click to use your points
