07-06-2022 04:38 PM
According to this help article: https://www.publicmobile.ca/en/on/get-help/articles/long-distance-and-us-roaming-add-ons
Making a Call to someone outside of Canada ---> In Canada: Canada-wide and to the U.S. ---> Excluding calls to the U.S., you will require a Long Distance Add-On
Does this mean calling a US number while you're in Canada is free? Since it says excluding calls to the US, then I'll need long distance add on?
07-06-2022 07:39 PM
Regarding clarity.....please can you interpret this catch-22 for me?
Can the terms of service change? Yes, Public Mobile has the right to change any of the terms of service, including rates, without notice. Changes become effective thirty days after being posted at publicmobile.ca/plans. By purchasing service after a change is posted, including by continuing to top up your account, you accept the current terms of service.
07-06-2022 04:57 PM
@hTideGnow Yes, you are right but the wording could definitely be updated to stop any confusion, me thinks.. 😊
07-06-2022 04:54 PM - edited 07-06-2022 04:59 PM
@dabr wrote:@LegusY I'm assuming you are referring to the following part regarding calls to the US, and yes that wording is a bit confusing/misleading..
In Canada: Canada-wide and to the U.S. Uses plan minutes before Long Distance Add-On minutes. Excluding calls to the U.S., you will require a Long Distance Add-On Uses plan minutes. If your minutes have been used, time will be taken from your Long Distance Add-On minutes.
HI @dabr it's confusing but not misleading, just need to read different lines on the table.. LoL
07-06-2022 04:53 PM
HI@LegusY if you just joined, look forward to December. PM has been giving Long Distance call bonus in the last 3 Christmas. Those Long distance bonus minutes can be use to call some countries and US is one of them.
If you are in limited minutes plan ($15 and $13), the add-on can be used as outgoing minutes to call Canada as well
07-06-2022 04:53 PM
| In Canada: Canada-wide and to the U.S. | Uses plan minutes before Long Distance Add-On minutes. | Excluding calls to the U.S., you will require a Long Distance Add-On | Uses plan minutes. If your minutes have been used, time will be taken from your Long Distance Add-On minutes. |
07-06-2022 04:53 PM
Oh I read it as it is.
I didn't think of the wording as the feature/name of the plans. It makes sense now thank you!!
07-06-2022 04:50 PM - edited 07-06-2022 04:50 PM
@LegusY wrote:I appreciate the support but the help article's language suggests that it should be free. Don't you think so?
HI @LegusY NO, the wordings are no problem.
when they say In Canada: Canada-wide and to the U.S., it means if your plan include Canada-wide and to the US calling (plans $50, $60 and $70)
if you have a plan ($15, $25, $35, $40), you should read the line above: In Canada: Canada-Wide
those plans are "Canada-Wide" plans
07-06-2022 04:44 PM
07-06-2022 04:44 PM - edited 07-06-2022 04:44 PM
@LegusY wrote:
PM won't charge me for services that I cannot use right? Just asking because I don't want to get charged if it ended up working haha
Yes, you are perfectly correct. PM is prepaid, you pay before you use the service. So, if it is a chargeable calls and you don't have the add-ons, it won't work. If it works, then you won't get extra charge
07-06-2022 04:43 PM
Check before you buy the USA calling add on.....there are some numbers that you cannot call. Likely won’t affect you.....but check the list.
07-06-2022 04:43 PM
Alright, I'm going to go ahead and try calling my friend from the US.
07-06-2022 04:41 PM
@LegusY No it's not free but you can purchase US LD minutes add-on $15/1000 minutes to call the US from Canada (not roaming add-on which is to be used only in the US). Remaining minutes from the add-on stay on your account until depleted. Make sure to first add funds and then back to purchase the correct add-on (2 step).
07-06-2022 04:41 PM - edited 07-06-2022 04:41 PM
@LegusY No, calling to US require US calling Add-ins (UNLESS you are on $50 plans and above, which include US calling)
1000 U.S. Long Distance Minutes - $15.00 (10 Reward points)
but you can call for free if you don't mind using app. Download VoIP app TextNow and you can call US and Canada for free
