US roaming cannot make calls.
Sprite34
Asn not touched. Automatic roaming. Tried manually using Verizon, at&t and T-Mobile. Every call has a fast busy. Rebooted pulled sim. Dealing with a death in the family and really need my phone. Phone is less than a year old. Thc
1 REPLY 1
@Sprite34
You will need to enable VoLTE to make and receive calls in USA since 3G is no longer available.
Check the IMEI of your phone to see if it is compatible.
https://www.publicmobile.ca/en/get-help/articles/volte
