yesterday
I read and understand porting from Koodo Prepaid is different. I need to activate with a temporary number first, which I did and the temp number is working great
I went to my app and request Transfer number but I got and error. What did I do wrong? From my understand, all Koodo numbers can be ported into Public
yesterday
thanks both
yesterday
hi @rulolalula support usually reply within 2 to 4 hours. But given it is late at night and PM has some issue with login, you likely won't get a reply till tomorrow
yesterday
@rulolalula Most like get reply from support tommorow now at this point (time of night ) but
yesterday
thanks for quick reply. messaged, easy enough. Hope it got done soon
yesterday
@rulolalula That’s right you need temp PM
number but now you need support to transfer the number for you
yesterday
hi @rulolalula
You have done most the steps correctly except the last step.
Instead of request porting on the app, you need to ask support agent to port with a ticket. But My Account login is currently down, so , please message PM support and ask them for manual port
