Double charged for subscription
Ellagirl4
Hi,
I recently changed my subscription as I didn’t need 100GB of data.
I’ve now been charged twice today for my phone plan, one charge is the old price and one is the new price.
please help
2 REPLIES 2
@Ellagirl4  You have to ask support to help with that
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
hi @Ellagirl4 did you request a plan change today, after the renewal and used Change Now option ?  If so, that is the normal behavior with the change now option
but there's a slight chance that support can reverse it , please check with them
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
