Koodo Prepaid Number Transfer
kiki55
looking for help from a customer support agent to transfer my koodo prepaid number to my new public mobile account .  thanks.
2 REPLIES 2
kiki55
Thanks.  I was able to submit a ticket using your directions.
hi @kiki55 have you activated your account with a new number? contact them only if you have done so and the new line is working.  Then, you can submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
