01-05-2025
09:13 AM
01-05-2025
07:58 PM
computergeek541
I activated my temp number in Public Mobile on Dec 30 2024 and tried to port my number from Koodo Prepaid. The App doesn't allow me to port it; I was instructed to open a ticket and send a private message to an agent to get it done. 7 days later it's still not done, no response, even after multiple follow-ups. Can somebody let me know what's going on? Is there any way I can talk to a live person?
01-16-2025 03:02 PM - edited 01-16-2025 03:06 PM
@slusagm In Safari on my iPad mini it is the same in both mobile and desktop mode, drop the magnification to 100% or below and the envelope appears, above 100% it disappears.
01-16-2025 03:00 PM - edited 01-16-2025 03:00 PM
envelope icon or not depends on 100% or not.
If the system detected you are using mobile browser, it won't show for sure
on a desktop browser ( you can also select "desktop mode" when you are on the phone), it depends if you have enough space for it to show 4 items on top , EN Bell Envelope Avatar, if not enough space, it will only show 3 of them and the envelope icon would be gone
01-16-2025 02:56 PM
@Luddite It disappears at anything over 100% in my browser but I'm using Safari on an iPad mini. If I reduce the magnification to where the envelope appears the text becomes far too small to easily read. Maybe PM could re-arrange the icons so that it is always visible? When people don't see an envelope they don't have a notification that there is new mail (unless they subscribe to email notifications) if they don't tap on their avatar for the drop down menu. It's happened a few times that people thought they didn't get a reply from customer service. Maybe put the FR or EN somewhere else so that the envelope always shows?
01-16-2025 11:58 AM
@Phil_Adelphus FYI: the envelope icon shows when, in my case, the magnification on my browser is set to 75%. Any higher and it's invisible.
The same thing also applies to the icons available when replying to a post; particularly annoying it affects the quote and image functions.
01-05-2025 09:45 AM
I do see the envelope and the bell icons, and checked them all. Nothing.
01-05-2025 09:44 AM
Thanks! I did send private message to them, and opened at least 3 tickets, zero response.
01-05-2025 09:38 AM
@JianmingLiang Note that if you don't see an envelope icon, many of us don't, you will need to tap on your avatar to the right of the bell icon to access Messages for the agent's reply.
01-05-2025 09:26 AM
Unfortunately, @JianmingLiang , there is no live support around here.
You will need to deal with the customer support agents for this.
Recommend sending another ticket advising of the wait for them to rectify.
