Esim transfer between 2 devices
Ritika123
Hi everyone,
i want to transfer my e-sim from one device to another. Can I do that, if so how?
I can’t even submit a ticket, it says error
CLWR
You need only to use 1 sim card.... then move between devices.... the esims are hard fixed to 1 and only 1 account and 1 device.... I found out the hard way
Sevcan
To transfer an eSIM from one device to another:
  1. Deactivate eSIM on the current device.
  2. Get new activation details (QR code or details).
  3. Activate eSIM on new devices using new information.
Priority
You'll have to sign into your Public Mobile Account on the device you'd like to switch the e-SIM to using the Public Mobile App, and than buy a new e-SIM so it installs on the new phone and deactivates the old one.
'Buy a Physical SIM Card or Activate e-SIM'
https://myaccount.publicmobile.ca/en/account/purchase-sim
ShawnC13
As of right now you are not able to transfer e-sims between devices.  It is on PM's radar so hopefully a feature for the future.
@Ritika123  You can’t transfer eSIM from one device to another . But you can request a new eSIM for $5 from in your my account or with help of support
private message   To CS_Agents click
LitlLdy
@Ritika123 wrote:
Hi everyone,
@Ritika123 , unfortunately not 😔. You would need to purchase a new eSIM!
The chatbot is broken! Sorry.
You can send a private message to a CS_Agent: ->   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
  • Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
