International Calling
BMcL
If I want to make an occasional international call from Canada what are the per minute rates? My plan does not include minutes outside of Canada and I do not want an add on.
10 REPLIES 10
@BKNS27 wrote:
@BMcL
You need to purchase a LD Add-on for these countries and rates of $15.
BMcL said that an add-on isn't wanted.  BMcL either wants to pay per minute (which doesn't work) or have a plan that includes the long distance.
cellphoneuser1
There are no per minute rates.  If it's not paid for already in a plan or add-on, the service doesn't work.  Take a look in your account if there is a $45 plan that includes some long distance minutes to some countries.  BKNS27 gave the list of countries that can be called with the $45 plan that includes some international long distance.
HI @BMcL
if you have short trip, better to use travel esim for data. US 1GB for 7 days will only cost you USD $6.50.  But for calls, you will need to use VoIP app like TextNow to use the app to make calls
@BMcL
for a short trip to US, the $15 talk/text 15 day add-on is a decent price to be able to use cell in US...even if it's just for a few days. I use that add-on for short weekend stays in Spokane.
@BMcL
Please note if you are on the $15 plan and switch to the higher Canada/USA plan. You won’t be able to switch back so check your account to see what the lowest plan you are eligible for when you switch back.
@BMcL  no, those are the only option at $15 for talk and text for $30 with data for 15 days. Unused amount would be forfeited.
Best to use wifi where possible.
@BMcL
There are only 15 day roaming packages.
If you travel to US often, you can consider a Canada-US plan.
https://subscribe.publicmobile.ca/en/ab/activation/plans/65GB-5Gspeed
@BMcL
You can use WhatsApp or TextNow for free calling and texting when connected to wifi.
Otherwise, you need to purchase a USA bundle Roaming Add-on for 15 days.
@BMcL
BMcL
My plan does not include USA minutes or data. For a short trip I don't want the 15 day add on. What are the ad hoc rates for calls, texts and data while in the USA?
