2 weeks ago
Whenever I call someone it does not make a ringing noise, it's just dead silence until the other person answers. I've tried so many things and can't figure out how to fix this.
2 weeks ago
hi@Eli26
the simple route might not work.
someone had similar issue and need to submit ticket and push for escalation to get it resolved
if you need to ask PM support agent and push for escalation, tell them to use the cased mentioned in the link above as reference
and to submit ticket, use the Expert Messaging in one of these ways:
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
https://expert-messaging.publicmobile.ca
Remember: Support hours of operation: 9 AM to 10 PM ET (yes, it is Eastern time as the support page clearly stated)
2 weeks ago - last edited 2 weeks ago
@Eli26 wrote:Whenever I call someone it does not make a ringing noise, it's just dead silence until the other person answers. I've tried so many things and can't figure out how to fix this.
Hello @Eli26
Try something simple first. Swipe down from the top of your phone. Click the airplane button. Leave it in Airplane mode for 5 minutes. Then, completely turn off your phone for 5 more minutes. Then, restart your phone, swipe down after it started and turn off Airplane mode. This reconnects your phone to the network and may help with your issue.
Contact customer service if you're still having issues.
Open ticket using Public Mobile Expert Messaging using your Community/EverSafe account.
Select Start a Chat to begin: https://expert-messaging.publicmobile.ca/guest/pre-chat
It is a network Handshake Delays or a VoLTE transition glitch
If you have an iPhone, make sure you update the Carrier Profile.
And also, proceed with a Reset network settings after a device reboot and test again to see if it works
if it is a Physical sim card, move it to another phone, try making call and move it back to your own phone and see if it resolves the issue
We have also seen people who need PM Customer support to reprovision the account to resolve this issue. To engage PM Customer Support, Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account. Select Start a Chat to begin:
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
