2 weeks ago
I thought I had a plan with unlimited Canada calling but today I've been told I’ve run out of minutes. Can you please advise what has changed?
2 weeks ago
hi @DorisErika
it is an unlimited calling plan, but some will run into the same calling problem.
Usually you just have to wait 5 minutes, do reboot your phone and calls will work again
but if that does not work, you will have to ask PM support agent to help.
You can submit a support ticket right at My Account and PM app using the Expert Messaging in one of these ways:
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
https://expert-messaging.publicmobile.ca
Remember: Support hours of operation: 9 AM to 10 PM ET
2 weeks ago
@DorisErika wrote:I thought I had a plan with unlimited Canada calling but today I've been told I’ve run out of minutes. Can you please advise what has changed?
Hey @DorisErika
That's a normal problem here with Public Mobile. It's been like that for years and they can't find the bug that's causing it. Just swipe down, go into airplane mode for 5 minutes, turn off phone for 5 minutes and then restart your phone and then turn airplane mode off. This reconnects you to the network. If you're still getting these errors, you can do a network reset. And if you're still getting these errors, contact PM.
2 weeks ago
All current plans are Canada unlimited. Ignore that message, hard reboot your phone and try again.
