I need an agent to contact me.
11-13-2024 02:08 PM
Your chat thing doesn't load any of its links and is honestly a really annoying loop. I am logged in why is it asking me to log in again with a link that does not load?
Why do in have to post about this on a public forum?
My Account
Service
11-13-2024 02:57 PM
@Nononononono In your settings or welcome email ?
11-13-2024 02:55 PM
Didn't see your reply but this is how in fixed it
11-13-2024 02:34 PM - edited 11-13-2024 02:35 PM
@Nononononono Was that previous number with public mobile ? If so you cannot transfer number from one PM account to another PM account . You would have to port it out to new carrier and back in on new PM account . But if the if the previous number has been suspended more then 90 days the account is closed and number gone . As for the eSIM check your phone setting siim manger maybe it already installed to the phone and just need to be set as primary / enabled or if iPhone they you toggle on “turn on this line . But I would just stick to physical sim over eSIM less hassle and easier to switch devices on the fly . In the end though it sounds like you will need some help form support as we can’t help with anything account related
adding @Nononononono check your welcome email for new account it should have the QR code there if not already installed on phone
11-13-2024 02:31 PM
you have to use the Public Mobile app to activate any new accounts now. You'll have apportunity to buy an esim in that process.
11-13-2024 02:29 PM
I had a previous number a long time ago. It says that number isn't valid for transfer. I signed up for a lower plan and it had me generate a new number. The esim refused to install, and now the app just loads into the account without any option to install the esim at all.
11-13-2024 02:27 PM - edited 11-13-2024 02:28 PM
@Nononononono They usually reply in 1-2 hours some times longer but
11-13-2024 02:27 PM
could be up to 24 hours...so good idea to pose your question here in the Community...we can likely help before Customer Support sees it. Give us a try.
11-13-2024 02:26 PM
How long do they usually take
11-13-2024 02:11 PM
try using this link to message Customer Support. Give them your acct number, ph number, name on acct and PM pin number too.
11-13-2024 02:10 PM - edited 11-13-2024 02:14 PM
Clear the cache on your browser and try login. You will need to type in Submit a Ticket or Contact Agent on Chatbot for an agent to help you.
Or pm a CS_Agent by click on your avatar then Messages>pen & paper icon and type in CS_Agent.
11-13-2024 02:10 PM
I can't submit a ticket because the link to the ticket doesn't load.
11-13-2024 02:10 PM
@Nononononono If you wanna share you issue with out giving personal info community might be able to help quicker . But if chat bot not working and you just rather as support
11-13-2024 02:09 PM
to have agent to get to you, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
