5 hours ago
Hello,
I have a question. I just sent a few private messages to an agent. There were back-and-forth replies, but I can not find them. How can I have access to my previous messages? I appreciate you helping me in this regard.
Best,
Sara
4 hours ago
Thanks
5 hours ago
@Paradisee Hymm well you can you log into your account ? If so you can change password and account PiN email to if you want to to be safe . But also note in your account you can change plans yourself and it’s best to choose change plan on next renewal and not immediately or you lose money on your current cycle . And with support changing plan for you it will be immediately plan change and you will lose money on current cycle
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
5 hours ago
Thanks @Handy1 but my concern is now if all messages from the agent was fake as I provided my information. Because I can not see my previous messages and his reply
5 hours ago
did you use email and not private message in Community? email won't work
I won't worry too much about spam or so. If you now see some private message from agent, just reply and continue the trouble shooting with them
5 hours ago
@Paradisee @Do you have another community account with different email ? If so that’s the account you need to be in to check the reply from support if I’m understanding that correctly
5 hours ago
I used a different email by accidentally sending private messages. However, through my email, I tried to access the messages, but nothing was there. The agent was supposed to change my plan as I requested, but since then, I have not received any message from him, and now all previous messages are gone. Worried about spam or something like that. Can it be?
5 hours ago
I clicked the envelope, nothing is there. I could see the replies from the agent but it seems there was no messages at first. I also tired through the email notification for the new messages and when I clicked the linked provided in the email, there is an error like the page doesn't exist.
5 hours ago
@Paradisee Is it possible you deleted them by accident ? Either way I would just sent another message and wait the reply . But if you like to share with the community with out giving personal info maybe we can help answer quicker then agent can
5 hours ago
If you were messaging an agent you should see the messages under Inbox, you can also select "Sent" with the drop down beside the Inbox to see what you have sent and who you sent it to. If there's nothing there, i can only guess you were on a different account.
5 hours ago
Thanks for your reply. I had access to the messages first, but now it seems they are gone. I clicked the envelope and nothing was there. Wonder if all replies from an agent were spam?
5 hours ago
After submitting ticket keep an eye on your community inbox for their reply , or you can use this link to the community in box. You can check the sent messages to in the inbox
5 hours ago
hi @Paradisee
use this link
or the long way is to click the Avatar and select My Message or if you see the envelope icon, it is there
