MMS picture messaging
stef10
cannot receive and sending photo  MMS picture messaging
12 REPLIES 12
@stef10 wrote:
where locate public mobile store in montreal
Public Mobile doesn't have any stores, and staff at Telus stores are unable to assist.
stef10
@stef10 uninstall and reinstall Google Message with reboot
If that does not work, engage support and ask them to re-provision the sim.
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
    (if you cannot receive 2FA via SMS, click "Didn't Receive code" or "Resend Code" and choose "Send email" to get 2FA)
stef10
not working
@stef10
Try create a new APN profile and set as active
APN: SP.MB.COM
    (Make it capital as it is case sensitive)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D      (or try:   4D4F)
hi @stef10
is the APN name correct?
stef10
hi @stef10
Android version would not make a difference.  The APN was set on the ROM and you need to update the APN settings.
please confirm if you made the change yet
stef10
Android 12
hi @stef10
is your mobile data working?
but please make the update first and test MMS again
stef10
phone ulefone note 14
@stef10
what phone are you using?
Telus (PM) has retired some legacy servers and old phones from 2017 before will be affected
and check if you have these APN settings
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
