09-04-2023 02:15 PM
Hey there! I can’t seem to connect to a real person on here - can someone walk me through how to cancel my account? 🙏🏼🙏🏼🙏🏼
09-04-2023 02:31 PM
Thank you so so much! I really appreciate the help! Fingers crossed this works haha.
09-04-2023 02:30 PM
so, after clicking resend code, Send Email is not an option like my screenshot?
again, to engage support, message them here:
09-04-2023 02:30 PM
@Selah You need to engage them private message using this direct link
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-04-2023 02:29 PM
Thanks for your help. There is only the “resend code” option, no others. Can you kindly tell me how to engage support to remove my credit card?
Thanks so much for the help, everyone
09-04-2023 02:26 PM - edited 09-04-2023 02:27 PM
@Selah Is there no option to for didn’t get code ? Or tap resend code a few times this should give you option to send code to email instead . But also as mentioned earlier you can get support to remove the credit card info on file right away . This will ensure you won’t be charged again after cancelling
09-04-2023 02:25 PM
try this: On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If still unable to login, you will have to engage support and ask them to remove your credit card from My Account so PM cannot charge you further
09-04-2023 02:23 PM
Thanks so much! Only problem I’m having is that when I go to login to either the app or online site, the EverSafe code comes up. I never receive a code to my cell phone number - only the initial one sent to my email. So I’m unable to login. Help?? 😅
09-04-2023 02:18 PM
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead. Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
09-04-2023 02:17 PM
@Selah You can port number out is one way or turn off auto subscribe also or get support to remove the credit card info right away
Turn auto pay OFF/ON 3 easy clicks
Or if you know the 4 digit PIN number
*611
direct link to support
