Refund payment
La11
I cancelled the contract with public mobile before I received my SIM card and now I want you to refund the money($38.08) you took from my account.
[email protected]
2 REPLIES 2
Phil_Adelphus
@La11   You can contact customer support via this link, an agent will reply at the envelope icon top right of this page, or tap your avatar to access Messages.
You should also tap the v in the circle top right of your post, select edit and remove your email address as this is a public forum that anyone on the internet can see.
eddieO
@La11, please open a ticket with a support agent to request a refund:
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
Also, please edit your post and remove your email address as this is an open forum that can be viewed by anyone on the internet. Click on the very small v inside a circle in the top right corner of your post.
