Hot spot
11-21-2021 02:43 PM - edited 01-04-2022 05:08 AM
Does anyone have any idea what might be the problem and how I can fix it?
When I put my hotspot on for my husband, he can sign in... It says connected but no internet available. I have checked that I can use the internet on my phone and it is working for me. My phone also shows that his phone is connected via hotspot. How can I get the internet to work for my husband?
Service
11-22-2021 07:06 PM
11-22-2021 06:57 PM
Well there you go! Thanks for the link and the difference between dun and DUN and now this issue done!
🤔Makes me wonder if the configuration file would have contained dun or DUN?
11-22-2021 06:52 PM
Hey Everyone! We are working!! 😁 Thanks for all your help. We did need DUN but it has to be all CAPS, apparently it is case sensitive. DUN is not the same as dun but does the same thing in the APN settings. A friend sent my son this post after we tried dun which did not work.
( Another suggestion we had tried but did not work was to remove rsc from the APN settings)
Thanks for all your help!!
Everyone here is GREAT! Thank you for putting so much of your effort and time into helping to solve this. 😊
11-22-2021 02:52 PM
@darlicious the other sim truck did not work.
Thanks for your your other info... Checking into it. 😊
11-22-2021 02:52 PM
Time to ask for a configuration file for your APN.🤞
11-22-2021 02:47 PM
@walker1 unfortunately the different sim did not work.
11-22-2021 01:46 PM - edited 11-22-2021 01:50 PM
It probably will work. That's why I mentioned it a couple of posts ago.
11-22-2021 01:44 PM
There is another thread dealing with this issue and the freedom sim card trick came up with same problem of dun not being allowed to be added. What version of OS are you running? The next best step would be asking customer support to see if they can text you the carrier profile that includes dun in the APN. If the CSA is unfamiliar with this procedure ask them to speak with Carlos or Silvio they are both familiar with method of changing your APN. This has been used in the past for the Umidigi X but I am not sure if it works for the hotspot as well. Hopefully it does.
11-22-2021 01:09 PM
@walker1 that is interesting and good to know. I only have PM sim but maybe I can find someone else who would let me try that.
11-22-2021 01:05 PM
@hTideGnow I will suggest that to my son.
In the meantime my husband can just use my phone when he needs/wants to check something online ( until his data resets on his renewal)
I've only had my phone a couple months. It was a good deal at the time and the camera is really good, and lots of internal storage plus ability to add a memory card for more, and has dual sim slots.. although that was giving me trouble a month or so ago as well, I took out the 2nd sim and things worked again. I'm not sure I would recommend umidigi to anyone else, it sounds to me like there are lots of problems with them.
11-22-2021 12:53 PM - edited 11-22-2021 12:55 PM
Sometimes when you install a sim card from a different service provider like Freedom , I think your phone will then let you make those changes to the APN settings.
Then you can reinstall your PM sim card.
11-22-2021 12:44 PM
@J-L maybe ask your son to send us some screenshot of the hotspot setup as well as the APN setup. Umdigi is a bit hard to setup sometimes.
11-22-2021 12:42 PM - edited 11-22-2021 12:45 PM
@hTideGnow I have not tried that yet myself, I did send that info to my son but he's probably not able to try anything right now ( at work).
As for the APN the only thing missing is the "dun" but we can't add that ( it says either the phone or the service provider won't allow you to make that change)
11-22-2021 12:37 PM
@J-L how about APN type and did you try to change the band to 2.4G?
11-22-2021 12:31 PM
@darlicious no "dun" is not there, that is one of the things my son is working on. Our phones were not able to add that so he has to attach the phone to his computer and try to change the settings through some round about way.
We do not have wifi at our house as we don't have access to reliable internet. We are just out of range, or the internet company tower is facing the wrong direction, ( we are NOT in a remote area either) so we only have our phone data for access to internet.
11-22-2021 08:07 AM
@J-L make sure AP band is 2.4 (Click on Advanced on the Hotspot page)
If still fail, can you go to the APN setting and try APN type as follow:
APN type: default,supl,mms
11-22-2021 03:41 AM - edited 11-22-2021 03:42 AM
Do you have "dun" in your APN?
Also are you attempting to set this up at home while on wifi? Turn off your wifi as it will take precedence.
Edit:
Oops I see you don't have wifi....ignore that then.
11-22-2021 02:06 AM - edited 11-22-2021 02:15 AM
Hi everyone! Thanks for all your tips, still not working, but I did get ahold of my son and he is having the same problem ( all 3 phones are umidigiA9Pro) He found something online that sounds similar to the tip @t_p suggested ( thank you @t_p ). Since I don't have internet except the data on my phone, my son is trouble shooting with his phone. If he gets the hotspot working then he will come get my phone and fix it for me too. I'll let you all know if we get it working and what needs to be done so it might help others withe same problem.(Sounds like we are not the only ones)
11-22-2021 01:52 AM
@softech thanks for that tip. I will have him check that ( if we ever get it working) It's my husband so I'm not worried he'll abuse it, and it's just when he needs to check something quickly until his data resets on next renewal, but yes always checking to be sure no auto updates etc is a good idea. Thanks for the reminder 😊 I hadn't thought of making it metered network especially if I ever hotspot for someone else.
11-21-2021 06:25 PM
@J-L hope your hotspot is working now.
Just a reminder, the client from the hotspot can easily drained all your mobile data as the client would treat it as usual Wifi. App update and OS update and all kind of cloud backup might start once it sees the Wifi (your hotspot).
To avoid this, make sure on your client, make the hotspot Wifi as "metered network".
11-21-2021 05:38 PM
@J-L wrote:Does anyone have any idea what might be the problem and how I can fix it?
If still stuck, check out this tip to see if it helps:
11-21-2021 03:35 PM - edited 11-21-2021 03:36 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
try manually selecting network "3G ONLY" or WCDMA only,
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
11-21-2021 03:31 PM
@hTideGnow I have Android. Everything for hotspot is set up. I didn't have to do anything really. I will try the reboot you suggested.
11-21-2021 03:18 PM
@J-L are you on Android or iOS ? I have checked my Android Hotspot, usually there is not much need to be done other than setting the name of the hotspot
try reboot both the phones (the one while hotspot setup and the one to connect) .. and make sure the one with Hotspot setup has mobile data turned on
11-21-2021 02:58 PM
Check your hotspot APN and on your husband's phone.
11-21-2021 02:47 PM
11-21-2021 02:46 PM - edited 11-21-2021 03:19 PM
Here is more info about setting up a hot spot.
Check your APN settings sp.mb.com is the correct one and since it worked then it's a device issue. Test with another phone to verify. Also make sure your APN type field contains dun in it. If not, add it.
