01-24-2025 09:19 AM
I recently refered a friend and while helping him set up his account I was not shown the spot to enter my referral code. Can I get this corrected so I can earn my rewards?
01-24-2025 09:25 AM
HI @Wm2
the spot to enter the code is on the Payment step, there is a button there for Referral code
you can still get the referral bonus, but you need your friend to open a ticket with PM support. He open the ticket and both of you will get the referral bonus
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
01-24-2025 09:21 AM
@Wm2 your friend that just joined and used your referral code will need to be the person to contact a support agent and the agent will be able to add the $10 credit to your friends account, and then you will be earning 1 point for each month that they remain a customer.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
