OnePlus 12r can't send MMS messages to iPhones after latest Android update
LeahG84
As the title describes, I can't seem to send picture messages (MMS) to iPhone users from my OnePlus 12R after the latest Android update. Does anyone have a fix for this? I have tried resetting my networks and changing my APN settings to the following, which has enabled me to receive MMS but not send. The issue so far as I can tell, has been limited to just iPhones.
My APN settings are as follows:
if it works for you, good, but remember Telus APN is slightly different from PM's
JMGoo
Things have changed again. Recent update to OnePlus again knocked out MMS pictures. It appears that Telus has changed the settings for the APN (see https://www.telus.com/en/support/mobile-device/pixel/10.0.0/configuring-your-cellular-internet-apn-s...).
The setting MMSC: http://aliasredirect.net/proxy/mb/mmsc has been changed to MMSC: http://aliasredirect.net/proxy/mmsc (dropped the /mb characters).
Best of luck!!
RavingRaven
@LeahG84
I'm happy to hear that helped.
@softech
You might want to update the solution to include 4D4F.
LeahG84
This did it! The only difference was I had to set the MVNO to 4D4F and it did the job!
Neil11
You will need to contact customer service agent to fix your issue.  Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
@LeahG84
did you just update the OS?  There has been some issue with OnePlus after the Android upgrade
as to your have problem with just sending to iPhone? honest, I don't think it is your phone problem, your phone just sent out and don't really care iPhone or not.   There is only a slight chance that you are not really sending out MMS but you were sending RCS and your iPhone friends have not setup to receive RCS yet.  So, check if you were sending MMS or RCS
But maybe check the ARN again.  With OnePlus, there might be a bit more work than simply updatingMany confirmed that you need to delete the current APN profile first.  Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces.  Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
         (or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
