Forgot email to sign in
Lyss6527
Hi there my sister forgot her account email address for her account and can not go on to renew her card for auto pay.
darlicious
@Lyss6527
Your sister will have to contact customer support via private message. Tell her to put "forgot login credentials" in the subject line and leave a detailed message.
Have her keep an eye on the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times but expect a reply within an hour.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
Dunkman
@Lyss6527
Your sister can try to check her different email accounts for the welcome to Public mobile email when she first signed up.  Then login in with password or reset password.
Otherwise, she would need to contact customer service agent to access her self service account.
Chat with Simon and submit a ticket for CSA help.
https://www.publicmobile.ca/en/ab/get-help
@Lyss6527   You can use Forgot password link and try any possible email address you have.  If you got the correct one, then it will move to Step 2 , then you just need to answer the security question to finish resetting the password
If still does not work, then you can open ticket with PM Support:
1. For faster response (2-48 hours), Click the direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
JL9
If she can't find it though webmail buly searching public Mobile. She can reach out to a CSA to answer verification questions to get this resolved.
JoyLuck
Contact a CSA:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
