11-04-2024 11:03 AM
Hi ,
I am on esim. My data and incoming calls are not working. I have an I phone. I did reset network settings, no luck. Please help.
11-04-2024 11:12 AM
hi @ITZNOTEASY make sure you take out the old carrier sim card or disable it of it is eSIM
for PM eSIM, set as Primary and Turn on this line and test again
and with incoming calls problem, could be a failed poert. check with PM porting support team and confirm. I will send you the number to PM Porting support team Please check your community inbox
11-04-2024 11:05 AM - edited 11-04-2024 11:06 AM
@ITZNOTEASY Did you just port number over ? If so did you leave old providers sim in the phone and reply YES to the confirmation text to port ? If yes try removing old providers sim and set your eSIM to primary
if you missed the confirmation text to port I can private message you the porting team number to re trigger the port request for you
11-04-2024 11:04 AM - edited 11-04-2024 11:05 AM
did you only recently activate a new PM account and attempt to port your number to PM ?
added clip from Help Files...
https://www.publicmobile.ca/en/bc/get-help/articles/transfer-your-number
