Public Mobile Account
JoePublic1
Hello,
Did my account get set up properly?
Thanks,
Joe
eddieO
@JoePublic1 best way to know is to test your calling, text and data. For calling and text, check to see that it's working both ways, you can call out and receive as well.
@JoePublic1  Does your PM sim work can you make calls use text use data ? Can you log into your account website or app and confirm it’s active ?
@JoePublic1
If you can login to your account on the PM app or online then it was setup properly.
Finally, if you were charge for a plan on step 6. You should be good and setup was done.
