Access to 5G network.
Immune
As most are , I just received a message regarding another network provider with interesting features and pricing. However just maybe their advertising maybe a bit misleading. They advertise “access to 5G network “. This seems to me a bit in the grey area because access could mean even 3G speeds accessing the 5G network. Maybe I’m wrong ?
7 REPLIES 7
hi @Immune for most people, 4G with 100Mbps is good enough.  And as I said, you still can access both 4G and 5G network , so it is not bad
kb_mv
@Immune PM has 4G plans on offer. If you have a 5G capable phone you can connect to the 5G network but as noted above, speed will be capped at the speed of, in this case, the 4G plan you are on.
Immune
That’s what wasn’t clear to me - at first glance when I saw the 5G in bold letters I thought- hey that’s a great deal but now I understand.
Will stick with PM 4G plan.
@Immune @Any one can access the different network so long as there phone is compatible , so one in 3G plan can access 5G network it’s Just it  will be capped  to 3G speed
hi @Immune whichever plan you have, 3G or 4G or 5G, you can access  5G network.  Just that the speed  will be capped based on your plan
