01-10-2025 02:47 PM
01-10-2025 03:09 PM
@jknezaurek Is data working? If text and data are working it's likely your phone is not VoLTE capable/approved in which case voice calls will not work. Make sure you're connecting to AT&T, T-Mobile or Verizon, try all of them. Best to try 4G if 5G isn't working. But if your phone is not VoLTE then your only option for voice calls is to try 2G on T-Mobile or use a voip app since data will still work. Here's the list of VoLTE phones
01-10-2025 02:59 PM
Do you have Roaming turned on?
Maybe turn phone Off and On again?
