07-13-2024 02:17 PM
Why is this so difficult? How do I change the number of rings until the phone jumps to voicemail for an incoming call? I did this *61*1xxxyyyzzzz*11*20# and my phone tells me "Connection problem or invalid MMI code". what in do I do to change the number of rings???
07-14-2024 10:46 AM
no, it's a problem with PM system, no community can help. Need PM to check the account
07-14-2024 10:20 AM - edited 07-14-2024 10:23 AM
07-13-2024 07:56 PM
did you check with PM?? you have send them a ticket and ask?? this is a system problem, beyond what community members can help
07-13-2024 07:41 PM
none of this stuff works. It keeps telling me "connection problem or invalid MMI code". on two phones actually.
it could not be more ridiculous that I cannot set the number of rings. voicemail is useless as no one will now wait 12 rings to leave a message. how can this be so stupid?
07-13-2024 04:50 PM
@gary123123 the steps above would work if conditional forwarding works on your phone.
If conditional forwarding does not work, some mentioned PM support can help to restore the functionality for conditional forwarding and the rings before voicemail would then work. Test it
07-13-2024 04:42 PM
@gary123123, found this solution that was given a few years ago:
Dial this sequence: *61 *61475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait - choose from the following options:
For one ring, enter 5
For two rings, enter 10
For three rings enter 15
For four rings, enter 20
For five rings, enter 25
For six rings, enter 30 (this is the maximum number of rings/seconds).
Example: *61*16475804001*11*20#[SEND or CALL] - sets your phone to ring four times (20 seconds) before going to your voicemail.
07-13-2024 02:18 PM - edited 07-13-2024 02:23 PM
@gary123123 I don’t think you can change it , unless you have setting in your phones settings
found this for Samsung if that what you happen to have @gary123123
