07-14-2024 08:51 AM - last edited on 07-14-2024 01:37 PM by computergeek541
I became a Mobile Customer with a new cell number. All was good. Then I decided to Transfer my Bell cell # to PM via transfer feature. Line is now transferred, call are coming through but within my settings>cellular under sims it’s still showing the old original number. I’ve tried powering off/on, suspended my service then resumed but the old number continues to appear under the SIMs section. I transferred the number using eSIM on my iPhone. How to get the new transferred # to properly show.
07-14-2024 09:47 AM
Thank you Handy1 for your suggestion. I appreciate you’ve taken the time to help. Your suggestion to reset network settings on my iPhone solve the issue. Have a great day!
07-14-2024 09:29 AM
@Berghouse Try resetting network settings . See if that fixes the issue
