Picture messages not downloading/loading
Eddie88
When people send me MMS images they do not load or download
Here's what I've tried:
Taking out SIM / resetting SIM card
Restarting phone
Turning airplane mode on/off
Making sure I'm connected to mobile data network
I need public mobile to fix this ASAP, it's what I'm paying for
Mary490
On iPhone, this happens to me if my storage is full
EB0
Hi @Eddie88
Pixel 2XL may not support MMS, please check the link for the supported phones
 https://www.publicmobile.ca/en/on/get-help/articles/picture-messaging-updates?_gl=1*b8azbk*_gcl_au*M....
Eddie88
My phone is Pixel 2 XL
It doesn't show the "MMSC proxy" field only "Proxy" and "MMS proxy" but not a MMSC PROXY field... so where do I enter the https://mmscproxy.mobility.ca/ ??? in the Proxy or MMS proxy?
Eddie88
I've also tried that Changing APN Settings on Android Phones | Public Mobile it doesn't work
EB0
@Eddie88
If you have android phone, check your APN settings (Android Phones Only):
  1. Open your phone’s settings and tap:
  • Access Point Names
  • New APN settings
  1. Verify the following field match:
Sansan
@Eddie88  what type of phone do you have? See if your phone has the following. If not, delete and add the below  for android.
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or default,mms,agps,supl,fota,hipri
